Working with the AI agent
Last updated About 22 hours ago
You can guide the agent with a description, then refine the design over several requests.
A useful request explains:
The goal: what you want to create or change.
The constraints: dimensions, layout, or elements to preserve.
The context: which part of the scene you mean.
For example:
Create a single-storey garden studio, approximately 6 × 4 metres, with a large opening toward the garden.
Then:
Keep the building footprint and make the roof slope toward the back.
When changing an existing design, select the relevant object and refer to it explicitly or use the select and sketch tool to give more precise instructions:
Move the selected table closer to the window and leave the other furniture unchanged.
Review each result
Check the model from more than one viewpoint. If something is wrong, explain what differs from your intention and ask for a focused correction.
You can also use Arkio’s modeling tools to make changes directly, then continue the conversation.
For this beta, we’re particularly interested in moments when the agent misunderstood you. Share the original request, what you expected and what happened.
Report an issue from Arkio web
