Import and export models in Arkio Web
Last updated 1 day ago
Open Arkio on your PC and connect it to your Arkio Cloud group. You can manage groups at cloud.arkio.is.
Open Arkio Web and sign in.
Open the Cloud tab, enter an invite code for the same group, and select Join.
Keep Arkio running on your PC while exporting and syncing files.
Open your model and prepare the geometry you want to bring into Arkio. Use your application's Arkio Export command. For application-specific steps, see our guides for Revit, Rhino and SketchUp.
4. Place the model
Place in scene: Position the model manually. Each click places a copy until you select Done, press Esc, or choose another tool.
Place at origin: Place the model at its original coordinates in the current scene or in a new scene.
Inspect BIM properties and control visibility
Some imported models include element properties and layers. Availability depends on the source model, how it was exported, and your Arkio plan. If a panel is locked, select See plans to check access.
Open View settings → BIM data.
Use Select to click an element in the imported model.
Read its property groups, or search for a property name or value. Click a property row to copy its value.
Arkio-created geometry and plain model imports may not include BIM properties. Seeing the geometry does not mean that element data was included in the export.
Open View settings → Layers to show or hide imported models and their available layers. Use the eye controls or Solo to focus on one model or layer and Unsolo to return to the previous visibility. You can also search by model or layer name.
Use scene notes to record questions or changes while reviewing an imported model. When a note is placed on a supported BIM element, its element reference helps identify the part being discussed.
See Review designs with scene notes for the full feedback and issue-export workflow.
Update an imported model
Open Import & export → Export.
Choose Revit, Rhino, or SketchUp, where available for your account.
Download the export ZIP to your PC and extract all its files into the same folder.
Use the updated Arkio plugin's Import command in your design application.
Revit: Select the extracted .arkioexport file and keep its companion files together.
Rhino: Keep all extracted files together, including materials, textures, and companion files, then import through the Arkio Rhino plugin.
SketchUp: Select the extracted GLB file in the Arkio plugin's Import dialog.
GLB, OBJ, and IFC exports are also available for other workflows. Export formats carry different scene content; IFC currently includes Arkio geometry but excludes imported models, props, maps, sketches and textures. Browser export downloads are limited to 256 MB.
If your model does not appear
Check that Arkio on your PC is running and that both applications are connected to the same Cloud group before you import the file again to Arkio on your PC
Wait for export, processing, and Cloud sync to finish, then select Check now.
Check the Import panel for a failed import and use Retry when available.
Check that supporting files and textures are included. For large models, try exporting a smaller selection first.
If the model is listed but not visible, check its units, orientation and placement.
For current restrictions, see Known issues and limitations. If the problem continues, report an issue from Arkio Web and include the source application, file type, approximate size, and any error messages.
